/INIVEL/NODE
Block Format Keyword Initialize translational and rotational velocities on each node in the global or in a given coordinate system.
| /INIVEL/NODE/inivel_ID/unit_ID | |||||||||
| inivel_node_title | |||||||||
| node_ID | Skew_ID | Vxt | Vyt | Vzt | |||||
| Vxr | Vyr | Vzr | |||||||
| inivel_ID | Initial velocity block
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| inivel_node_title | Initial velocity block
title. (Character, maximum 100 characters) |
| node_ID | Node identifier on which
specified initial velocity is applied. (Integer) |
| Skew_ID | Skew identifier.
(Integer) |
| Vxt | X component in the local
skew of the translational velocity. (Real) |
| Vyt | Y component in the local
| Vzt | Z component in the local
| Vxr | Rotational velocity in the
local skew. (Real) |
| Vyr | Rotational velocity in the
| Vzr | Rotational velocity in the
- This card can be generated with /STATE/NODE/VEL.
