/MAT/LAW19 (FABRI)
Block Format Keyword This law defines an elastic orthotropic material and is available only for shell elements. It is used to model airbag fabrics.
/MAT/LAW19/mat_ID/unit_ID or /MAT/FABRI/mat_ID/unit_ID
mat_title
ρ i
E11 E22 ν 12
G12 G23 G31
RE   ZeroStress Fscale_Por sens_ID
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title
ρ i Initial density
(Real)
[ kg m 3 ]
E11 Young's modulus in direction 1.
(Real)
[ Pa ]
E22 Young's modulus in direction 2.
(Real)
[ Pa ]
ν 12 Poisson's ratio.
(Real)
G12 Shear modulus.
(Real)
[ Pa ]
G23 Shear modulus.
(Real)
[ Pa ]
G31 Shear modulus.
(Real)
[ Pa ]
RE Reduction factor value.
Minimum value, RE > 0.001
Default =1.0 (Real)
ZeroStress Zero stress flag.
= 0
= 1
Full stress reduction - compressive and tensile initial stresses are set to zero up to the reference state. This option must be used if the airbag folder has generated initial tensile stresses.
(Real)
Fscale_Por FVM internal scale factor of surface porosity. 3
Default set to 0.0 (Real)
sens_ID Sensor identifier. 4
Example (Airbag)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                  ms
#-  2. MATERIALS:
/MAT/FABRI/1/1
Fabric
#              RHO_I
              1.5e-9
#                E11                 E22                NU12
                 500                 500                   0
#                G12                 G23                 G31
                  10                  10                  10
#                R_E                              ZEROSTRESS          Fscale_pro   SENS_ID
                 .01                                       0                   0         0
#ENDDATA
/END
  1. Material Law 19 must be used with /PROP/TYPE9 (SH_ORTH) (Orthotropic shell element).
  2. The reduction factor RE is used to ease the Young's modulus when the airbag fabric is in compression:
    clip0060
  3. Fscale_Por is used in LAW19 with surf_IDin > 0 in either the /MONVOL/FVMBAG (Obsolete) or /MONVOL/FVMBAG1 card, to define internal surface porosity ranging from 0 (no porosity) up to 1 (full porosity).
  4. The sens_ID is used only with ZeroStress > 0 and reference state geometry. This ensures the stability of the mesh deformed from the reference configuration. The pre-constrained state will be released at the time determined by the sensor activation. This is useful for airbags with a delayed expansion time.
