/MAT/LAW68 (COSSER)
Block Format Keyword This law describes the honeycomb material.
/MAT/LAW68/mat_ID/unit_ID or /MAT/COSSER/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
E11 | E22 | E33 | |||||||
G12 | G23 | G31 | |||||||
fct_ID11i | fct_ID22i | fct_ID33i | Iflag1 | Fscale11i | Fscale22i | Fscale33i | |||
fct_ID12i | fct_ID23i | fct_ID31i | Iflag2 | Fscale12i | Fscale23i | Fscale31i | |||
fct_ID21i | fct_ID32i | fct_ID13i | Fscale21i | Fscale32i | Fscale13i | ||||
fct_ID11r | fct_ID22r | fct_ID33r | Fscale11r | Fscale22r | Fscale33r | ||||
fct_ID12r | fct_ID23r | fct_ID31r | Fscale12r | Fscale23r | Fscale31r | ||||
fct_ID21r | fct_ID32r | fct_ID13r | Fscale21r | Fscale32r | Fscale13r |
mat_ID | Material identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material title (Character, maximum 100 characters) |
Initial density (Real) |
E11 | Young's modulus (Real) |
E22 | Young's modulus (Real) |
E33 | Young's modulus (Real) |
G12 | Shear modulus (Real) |
G23 | Shear modulus (Real) |
G31 | Shear modulus (Real) |
fct_ID11i | Initial yield stress function identifier
in direction 11. (Integer) |
fct_ID22i | Initial yield stress function identifier
in direction 22. (Integer) |
fct_ID33i | Initial yield stress function identifier
in direction 33. (Integer) |
Iflag1 | Strain formulation for yield functions
11, 22, and 33.
(Integer) |
Fscale11i | Initial yield stress scale factor on
function 11. Default = 1.0 (Real) |
Fscale22i | Initial yield stress scale factor on
function 22. Default = 1.0 (Real) |
Fscale33i | Initial yield stress scale factor on
function 33. Default = 1.0 (Real) |
Initial failure strain in tension in
direction 1. (Real) |
direction 2. (Real) |
direction 3. (Real) |
fct_ID12i | Initial shear yield stress function in
direction 12. (Integer) |
fct_ID23i | Initial shear yield stress function in
direction 23. (Integer) |
fct_ID31i | Initial shear yield stress function in
direction 31. (Integer) |
Iflag2 | Strain formulation for shear yield
functions 12, 23, and 31. (Integer) |
Fscale12i | Initial shear yield stress scale factor
on function 12. Default = 1.0 (Real) |
Fscale23i | Initial shear yield stress scale factor
on function 23. Default = 1.0 (Real) |
Fscale31i | Initial shear yield stress scale factor
on function 31. Default = 1.0 (Real) |
Initial failure strain in direction
12. (Integer) |
23. (Integer) |
31. (Integer) |
fct_ID21i | Initial shear yield stress function in
direction 21. (Integer) |
fct_ID32i | Initial shear yield stress function in
direction 32. (Integer) |
fct_ID13i | Initial shear yield stress function in
direction 13. (Integer) |
Fscale21i | Initial shear yield stress scale factor
on function 21. Default = 1.0 (Real) |
Fscale32i | Initial shear yield stress scale factor
on function 32. Default = 1.0 (Real) |
Fscale13i | Initial shear yield stress scale factor
on function 13. Default = 1.0 (Real) |
fct_ID11r | Residual yield stress function in
fct_ID22r | Residual yield stress function in
fct_ID33r | Residual yield stress function in
Fscale11r | Residual yield stress scale factor on
Fscale22r | Residual yield stress scale factor on
Fscale33r | Residual yield stress scale factor on
Transition strain in direction
11. (Real) |
22. (Real) |
33. (Real) |
fct_ID12r | Residual shear yield stress function in
fct_ID23r | Residual shear yield stress function in
fct_ID31r | Residual shear yield stress function in
Fscale12r | Residual shear yield stress scale factor
Fscale23r | Residual shear yield stress scale factor
Fscale31r | Residual shear yield stress scale factor
12. (Integer) |
23. (Integer) |
31. (Integer) |
fct_ID21r | Residual shear yield stress function in
fct_ID32r | Residual shear yield stress function in
fct_ID13r | Residual shear yield stress function in
Fscale21r | Residual shear yield stress scale factor
Fscale32r | Residual shear yield stress scale factor
Fscale13r | Residual shear yield stress scale factor
Example (Honeycomb)
#RADIOSS STARTER
/UNIT/1
unit for mat
kg mm ms
#- 2. MATERIALS:
/MAT/LAW68/1/1
honeycomb
# RHO_I
3.2E-5 0
# E_11 E_22 E_33
40 40 80
# G_12 G_23 G_31
15 30 30
# Initial tension/compression
#fun_ID11i fun_ID22i fun_ID33i Iflag1 Fscale11i Fscale22i Fscale33i
13 14 15 0 1 1 1
# Tension/compression
# Eps_max11i Eps_max22i Eps_max33i
.12 .12 .12
# Initial shear
#fun_ID12i fun_ID23i fun_ID31i Iflag2 Fscale12i Fscale23i Fscale31i
16 18 17 0 1 1 1
# Shear
# Eps_max12i Eps_max23i Eps_max31i
.14 .14 .14
# Initial shear
#fun_ID21i fun_ID32i fun_ID13i Fscale21i Fscale32i Fscale13i
16 18 17 0 0 0
# Residual tension/compression
#fun_ID11r fun_ID22i fun_ID33i Fscale11r Fscale22r Fscale33r
3 4 5 1 1 1
# Transition tension/compression
# Eps_trans11r Eps_trans22r Eps_trans33r
.022 .022 .022
# Residual shear
#fun_ID12r fun_ID23r fun_ID31r Fscale12r Fscale23r Fscale31r
6 8 7 1 1 1
# Transition shear
# Eps_trans12r Eps_trans23r Eps_trans31r
.041 .035 .035
# Residual shear
#fun_ID21r fun_ID32r fun_ID13r Fscale21r Fscale32r Fscale13r
7 7 8 0 0 0
#- 3. FUNCTIONS:
/FUNCT/3
sig11
# X Y
-100 .4
100 .4
/FUNCT/4
sig22
# X Y
-100 .4
100 .4
/FUNCT/5
sig33
# X Y
-100 .8
100 .8
/FUNCT/6
sig12
# X Y
-100 .3
100 .3
/FUNCT/7
sig13
# X Y
-100 .5
100 .5
/FUNCT/8
sig23
# X Y
-100 .5
100 .5
/FUNCT/13
sig11
# X Y
-100 .4
-.021 .4
-.02 .8
.02 .8
.021 .4
100 .4
/FUNCT/14
sig22
# X Y
-100 .4
-.021 .4
-.02 .8
.02 .8
.021 .4
100 .4
/FUNCT/15
sig33
# X Y
-100 .8
-.021 .8
-.02 1.6
.02 1.6
.021 .8
100 .8
/FUNCT/16
sig12
# X Y
-100 .3
-.041 .3
-.04 .6
.04 .6
.041 .3
100 .3
/FUNCT/17
sig13
# X Y
-100 .5
-.034 .5
-.033 1
.033 1
.034 .5
100 .5
/FUNCT/18
sig23
# X Y
-100 .5
-.034 .5
-.033 1
.033 1
.034 .5
100 .5
#ENDDATA
/END
- This law is compatible with 8-node brick elements, under integrated elements and Isolid =1 or Isolid =2 only.
- When switching from a volumetric strain formulation to a strain formulation, Iflag = -1 allows the same function definition to be retained.
- If one of the failure or shear failure strains is reached, the element is deleted.
- Transition strains define transition from initial to residual yield stress function.
- If one of the transition or shear transition strains is reached, element has yield stress described by residual functions, in each direction. Transition is applied to the neighbor elements.
