/MAT/LAW82
Block Format Keyword This keyword defines the Ogden material. This law is compatible with solid and shell elements. In general it is used to model polymers and elastomers.
/MAT/LAW82/mat_ID/unit_ID
mat_title
ρ i
N   v
μ 1 μ   2 μ   3
. . . N values of μ (five per line)
α 1 α 2 α 3
. . . N values of α (five per line)
D1 D2 D3
. . . N values of D (five per line)
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title
ρ i Initial density
(Real)
[ kg m 3 ]
N Order of the Ogden model.
v Poisson's ratio
Default value depends on D1 input. 2 (Real)
μ i ith Parameter (i = 1,N).
(Real)
α i ith Parameter (i = 1,N).
(Real)
Di ith Parameter (i = 1,N).
(Real)
Example (Rubber)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW82/1/1
LAW82 RUBBER
#              RHO_I
                1E-9                   0
#        N                            Nu
         2                          .495
#               Mu_i
                   2                   1
#            Alpha_i
                   2                  -2
#                D_i
                   0                   0
#ENDDATA
/END
Example (Hyper-elastic Rubber)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW82/1/1
Rubber
#              RHO_I
                2E-9
#        N                            Nu
         3                             0
#               Mu_i
            1.061898            .0578289            .0159176
#            Alpha_i
             .428246             5.71269            -4.59726
#                D_i
                1E-4                   0                   0
#ENDDATA
/END
  1. The strain energy density W MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGxbaaaa@39B3@ is computed using the following equation:(1)
    W = ∑ i = 1 N 2 μ i α i 2 ( λ ¯ 1 α i + λ ¯ 2 α i + λ ¯ 3 α i − 3 ) + ∑ i = 1 N 1 D i ( J − 1 ) 2 i
    with λ ¯ = J − 1 3 λ and J = λ 1 λ 2 λ 3
    where, λ i is the ith principal stretch.
  2. The initial shear modulus:(2)
    μ = ∑ i = 1 N μ i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd0Maey ypa0ZaaabCaeaacqaH8oqBdaWgaaWcbaGaamyAaaqabaaabaGaamyA aiabg2da9iaaigdaaeaacaWGobaaniabggHiLdaaaa@413C@
    The Bulk Modulus is calculated as K = 2 D 1 , based on the following rules:
    • If ν = 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4Maey ypa0JaaGimaaaa@396F@ , then D1 should be entered entered.
    • If ν ≠ 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4Maey iyIKRaaGimaaaa@3A30@ , D1 input is ignored and will be recalculated and output in the Starter output using the formula:(3)
      D 1 = 3 ( 1 − 2 v ) μ ( 1 + v ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiramaaBa aaleaacaaIXaaabeaakiabg2da9maalaaabaGaaG4maiaacIcacaaI XaGaeyOeI0IaaGOmaiaadAhacaGGPaaabaGaeqiVd0Maaiikaiaaig dacqGHRaWkcaWG2bGaaiykaaaaaaa@43E2@
    • If ν = 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4Maey ypa0JaaGimaaaa@396F@ and D1 = 0, then a default value of υ = 0.495 is used and D1 is calculated using Equation 3
  3. To get a material without Poisson ratio effect, v should be defined with a small value (1e-10).
  4. Further explanation about this law can be found in "Non-Linear Elastic Deformations", by R.W Ogden, Ellis Horwood, 1984.
