/PROP/TYPE8 (SPR_GENE)
Block Format Keyword This spring property works with six independent modes of deformation. This spring accounts for nonlinear stiffness, damping and different unloading.
Deformation, force and energy based failure criteria are available. The general spring property is often used to model a joint connection between two parts.
/PROP/TYPE8/prop_ID/unit_ID or /PROP/SPR_GENE/prop_ID/unit_ID
prop_title
Mass I Skew_ID sens_ID Isflag Ifail Ifail2 Iequil
Loading index=1: Translation in X
K1 C1 A1 B1 D1
fct_ID11 H1 fct_ID21 fct_ID31 fct_ID41   δ min 1 δ max 2
F1 E1 Ascale1 Hscale1
Loading index=2: Translation in Y
K2 C2 A2 B2 D2
fct_ID12 H2 fct_ID22 fct_ID32 fct_ID42   δ min 2 δ max 2
F2 E2 Ascale2 Hscale2
Loading index=3: Translation in Z
K3 C3 A3 B3 D3
fct_ID13 H3 fct_ID23 fct_ID33 fct_ID43   δ min 3 δ max 3
F3 E3 Ascale3 Hscale3
Loading index=4: Rotation in X
K4 C4 A4 B4 D4
fct_ID14 H4 fct_ID24 fct_ID34 fct_ID44   θ min 4 θ max 4
F4 E4 Ascale4 Hscale4
Loading index=5: Rotation in Y
K5 C5 A5 B5 D5
fct_ID15 H5 fct_ID25 fct_ID35 fct_ID45   θ min 5 θ max 5
F5 E5 Ascale5 Hscale5
Loading index=6: Rotation in Z
K6 C6 A6 B6 D6
fct_ID16 H6 fct_ID26 fct_ID36 fct_ID46   θ min 6 θ max 6
F6 E6 Ascale6 Hscale6
Filtering forces
Fsmooth Fcut
prop_ID Property identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit Identifier.
prop_title Property title.
Mass Mass.
(Real)
[ kg ]
I Inertia.
(Real)
[ m 2 kg ]
Skew_ID Skew system identifier. 1
(Integer)
sens_ID Sensor identifier.
(Integer)
Isflag Sensor flag. 6
=0
Spring element activated when sens_ID activates and cannot be deactivated.
=1
Spring element deactivated when sens_ID activates and cannot be activated.
=2
Spring elements are activated, or deactivated state matches the sensor state and can switch back and forth. The spring initial length ( l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGSbWaaS baaSqaaiaaicdaaeqaaaaa@3835@ ) is based the spring length at the activation time.
(Integer)
Ifail Failure criteria.
= 0
Uni-directional criteria.
= 1
Multi-directional criteria.
(Integer)
Ifail2 Failure model flag.
= 0 (Default)
Displacement (or rotation) criteria.
= 1
Force (or moment) criteria.
= 3
Internal energy criteria.
(Integer)
Iequil Equilibrium flag. 4
= 0
No equilibrium.
= 1
Force and moment equilibrium.
(Integer)
Ki If fct_ID1i = 0: Linear loading and unloading stiffness.
If fct_ID1i0: Only used as unloading stiffness for elasto-plastic springs.
i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3 are translation DOF.
i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6 are rotation DOF.
(Real)
[ N m ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3
[ Nm rad ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6
Ci Damping. 1
(Real)
[ Ns m ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3
[ Nms rad ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6
Ai Nonlinear stiffness function scale factor.
Default = 1.0 (Real)
[ N ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3
[ Nm ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6
Bi Scale factor for logarithmic rate effects.
Default = 0.0 (Real)
Di Scale factor for logarithmic rate effects.
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@ if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3
[ rad s ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6
fct_ID1i Function identifier defining nonlinear stiffness f ( ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaaaiaawIcacaGLPaaaaaa@38D3@ . 5
= 0
Linear spring with stiffness K.
If Hi=4: Function defines upper yield curve.
(Integer)
Hi Spring Hardening flag for nonlinear spring.
= 0
Elastic spring.
= 1
Nonlinear elasto-plastic spring with isotropic hardening.
= 2
Nonlinear elasto-plastic spring with uncoupled hardening.
= 4
Nonlinear elastic plastic spring with kinematic hardening.
= 5
Nonlinear elasto-plastic spring with nonlinear unloading.
= 6
Nonlinear elasto-plastic spring with isotropic hardening and nonlinear unloading.
= 7
Nonlinear elastic plastic spring with elastic hysteresis.
(Integer)
fct_ID2i Function identifier defining force or moment as a function of spring velocity, g ( ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbWaae WaaeaaaiaawIcacaGLPaaaaaa@38D5@ .
(Integer)
fct_ID3i Function identifier.
If Hi =4: Defines lower yield curve.
If Hi =5: Defines residual displacement or rotation versus maximum displacement or rotation.
If Hi =6: Defines nonlinear unloading curve.
If Hi =7: Defines nonlinear unloading curve.
(Integer)
fct_ID4i Function identifier for nonlinear damping, h ( ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGObWaae WaaeaaaiaawIcacaGLPaaaaaa@38D5@ .
(Integer)
δ min i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda qhaaWcbaGaciyBaiaacMgacaGGUbaabaGaamyAaaaaaaa@3BF0@ Negative translation failure limit.
Default = -1030 (Real)
If Ifail2 = 0 or 1: Failure displacement. [ m ]
If Ifail2 = 2: Failure force. [ N ]
If Ifail2 = 3: Failure internal energy. [ J ]
θ min i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH4oqCda qhaaWcbaGaciyBaiaacMgacaGGUbaabaGaamyAaaaaaaa@3C01@ Negative rotational failure limit.
If Ifail2 = 0, 1: Failure rotation. [ rad ]
If Ifail2 = 2: Failure moment. [ N m ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaaci GGobGaeyyXICTaciyBaaGaay5waiaaw2faaaaa@3BFA@
δ max i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda qhaaWcbaGaciyBaiaacggacaGG4baabaGaamyAaaaaaaa@3BF2@ Positive translation failure limit.
θ max i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH4oqCda qhaaWcbaGaciyBaiaacggacaGG4baabaGaamyAaaaaaaa@3C03@ Positive rotational failure limit.
If Ifail2 = 0 or 1: Failure rotation. [ rad ]
Fi Abscissa scale factor for the damping functions for the g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ and h MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
Ei Ordinate scale factor for the damping function g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
(Real)
Ascalei Abscissa scale factor for the stiffness function f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
[ m ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3
[ rad ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6
Hscalei Ordinate scale factor for the damping function h MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
  1. The spring local system is defined by a skew coordinate system.The local system can be defined for each element in the spring definition (/SPRING). If a skew is not defined at element level, the /PROP/TYPE8 Skew_ID is used. If a system is not defined in the element or the property then the global system is used. The third node in element definition is not used to determine the local coordinate system of the spring.
  2. The spring has six degrees of freedom (DOF) in a skew system: δ 1 , δ 2 , δ 3 , θ 4 , θ 5 , θ 6 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda ahaaWcbeqaaiaaigdaaaGccaGGSaGaeqiTdq2aaWbaaSqabeaacaaI YaaaaOGaaiilaiabes7aKnaaCaaaleqabaGaaG4maaaakiaacYcacq aH4oqCdaahaaWcbeqaaiaaisdaaaGccaGGSaGaeqiUde3aaWbaaSqa beaacaaI1aaaaOGaaiilaiabeI7aXnaaCaaaleqabaGaaGOnaaaaaa a@4991@
    • The six DOF are independent. If the initial spring length is not equal to zero, the force equilibrium is correct but the moment equilibrium may not be correct. Therefore, it is recommended to use spring elements TYPE8 with a zero-length or with one of the two nodes fixed in all directions. For other non-zero length springs, the /PROP/TYPE13 (SPR_BEAM) spring property should be used.
    • Positive and negative spring deformations are not defined with the variation of initial length. The initial length can be equal to zero for all or a given direction. Therefore, it is not possible to define the deformation sign with length variation. A deformation is positive if displacement (or rotation) in the spring’s local system of node 2 minus the displacement (or rotation) of node 1 is positive.
  3. Force and moment computation.
    • δ is a translational DOF, the force in direction δ is computed as:
      F ( δ ) = f ( δ i A s c a l e i ) [ A i + B i ln ( max ( 1 , | δ ˙ i D i | ) ) + E i g ( δ ˙ i F i ) ] + C i δ ˙ i + H s c a l e i h ( δ ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGgbGaci ikaiabes7aKjaacMcacqGH9aqpciGGMbWaaeWaaeaadaWcaaqaaiab es7aKnaaCaaaleqabaGaamyAaaaaaOqaaiaadgeacaWGZbGaam4yai aadggacaWGSbGaamyzamaaBaaaleaacaWGPbaabeaaaaaakiaawIca caGLPaaadaWadaqaaiaadgeadaWgaaWcbaGaamyAaaqabaGccqGHRa WkcaWGcbWaaSbaaSqaaiaadMgaaeqaaOGaciiBaiaac6gadaqadaqa aiGac2gacaGGHbGaaiiEamaabmaabaGaaGymaiaacYcadaabdaqaam aalaaabaGafqiTdqMbaiaadaahaaWcbeqaaiaadMgaaaaakeaacaWG ebWaaSbaaSqaaiaadMgaaeqaaaaaaOGaay5bSlaawIa7aaGaayjkai aawMcaaaGaayjkaiaawMcaaiabgUcaRiaadweadaWgaaWcbaGaamyA aaqabaGcciGGNbWaaeWaaeaadaWcaaqaaiqbes7aKzaacaWaaWbaaS qabeaacaWGPbaaaaGcbaGaamOramaaBaaaleaacaWGPbaabeaaaaaa kiaawIcacaGLPaaaaiaawUfacaGLDbaacqGHRaWkcaWGdbWaaSbaaS qaaiaadMgaaeqaaOGafqiTdqMbaiaadaahaaWcbeqaaiaadMgaaaGc cqGHRaWkcaWGibGaam4CaiaadogacaWGHbGaamiBaiaadwgadaWgaa WcbaGaamyAaaqabaGcciGGObWaaeWaaeaadaWcaaqaaiqbes7aKzaa caWaaWbaaSqabeaacaWGPbaaaaGcbaGaamOramaaBaaaleaacaWGPb aabeaaaaaakiaawIcacaGLPaaaaaa@7D50@ with i =1,2,3
    • θ is a rotational DOF, the moment is computed as:
      M ( θ ) = f ( θ i A s c a l e i ) [ A i + B i ln ( max ( 1 , | θ ˙ i D i | ) ) + E i g ( θ ˙ i F i ) ] + C i θ ˙ i + H s c a l e i h ( θ ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGnbGaci ikaiabeI7aXjaacMcacqGH9aqpciGGMbWaaeWaaeaadaWcaaqaaiab eI7aXnaaCaaaleqabaGaamyAaaaaaOqaaiaadgeacaWGZbGaam4yai aadggacaWGSbGaamyzamaaBaaaleaacaWGPbaabeaaaaaakiaawIca caGLPaaadaWadaqaaiaadgeadaWgaaWcbaGaamyAaaqabaGccqGHRa WkcaWGcbWaaSbaaSqaaiaadMgaaeqaaOGaciiBaiaac6gadaqadaqa aiGac2gacaGGHbGaaiiEamaabmaabaGaaGymaiaacYcadaabdaqaam aalaaabaGafqiUdeNbaiaadaahaaWcbeqaaiaadMgaaaaakeaacaWG ebWaaSbaaSqaaiaadMgaaeqaaaaaaOGaay5bSlaawIa7aaGaayjkai aawMcaaaGaayjkaiaawMcaaiabgUcaRiaadweadaWgaaWcbaGaamyA aaqabaGcciGGNbWaaeWaaeaadaWcaaqaaiqbeI7aXzaacaWaaWbaaS qabeaacaWGPbaaaaGcbaGaamOramaaBaaaleaacaWGPbaabeaaaaaa kiaawIcacaGLPaaaaiaawUfacaGLDbaacqGHRaWkcaWGdbWaaSbaaS qaaiaadMgaaeqaaOGafqiUdeNbaiaadaahaaWcbeqaaiaadMgaaaGc cqGHRaWkcaWGibGaam4CaiaadogacaWGHbGaamiBaiaadwgadaWgaa WcbaGaamyAaaqabaGcciGGObWaaeWaaeaadaWcaaqaaiqbeI7aXzaa caWaaWbaaSqabeaacaWGPbaaaaGcbaGaamOramaaBaaaleaacaWGPb aabeaaaaaakiaawIcacaGLPaaaaaa@7DBD@ with i =4,5,6
  4. Equilibrium:
    • If Iequil = 0 (no equilibrium), then:(1)
      f ( θ ) = M 2 y = M 1 y
      Where,
      M 2 y MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbWaaS baaSqaaiaaikdacaWG5baabeaaaaa@3916@
      Moment in Y by N2.
      M 1 y MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbWaaS baaSqaaiaaikdacaWG5baabeaaaaa@3916@
      Moment in Y by N1.
    • If Iequil = 1, then:(2)
      M 1 y M 2 y M 1 z M 2 z
      (3)
      f ( θ ) = M 2 y M 1 y 2
      Where,
      Moment in Y by N2.
      Moment in Y by N1.
      M 2 z MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbWaaS baaSqaaiaaikdacaWG5baabeaaaaa@3916@
      Moment in Z by N2.
      M 1 z MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbWaaS baaSqaaiaaikdacaWG5baabeaaaaa@3916@
      Moment in Z by N1.
  5. If Ki is less than the maximum slope of the yield curve (Ki is not consistent with the maximum slope of the yield curve), a warning message is output and Ki is set to the maximum slope of the curve.
  6. Spring is activated and/or deactivated by the sensor defined in sens_ID and depends on Isflag:
    • Isflag = 0, the spring element is activated by the sens_ID and cannot be deactivated. The initial length of the spring is based on the spring length at time=0.
    • Isflag = 1, the spring element is deactivated by the sens_ID and cannot be activated. The initial length of the spring is based on the spring length at time=0.
    • Isflag = 2, the spring is activated and/or deactivated by sens_ID and can switch activation state multiple times. If sensor is activated, the spring is active; if sensor is deactivated, spring is deactivated. The spring initial length, l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGSbWaaS baaSqaaiaaicdaaeqaaaaa@3835@ , is the distance between spring nodes at the time of sensor activation.
