SS-T: 4130 Spot Weld Fatigue Analysis
Define and run spot weld fatigue analysis.
- Purpose
- SimSolid performs meshless structural
analysis that works on full featured parts and assemblies, is tolerant of
geometric imperfections, and runs in seconds to minutes. In this tutorial,
you will do the following:
- Create an SN Time fatigue loadcase.
- Define spot weld fatigue parameters.
- Solve and review the results.
- Model Description
- The following file is needed for this tutorial:
- SpotWeldFatigueAnalysis.ssp
Open Project
Review Model
Add Fatigue Material Properties
If an SN curve has already been assigned, skip this step. Check the assigned material properties by right-clicking Assembly in the Project Tree and selecting .
Create SN Time Analysis
Import Channels
Create Events
Edit Fatigue Solution Settings
For information about difference procedures supported for each setting, go to Apply Local Fatigue Solution Settings.
Run Analysis
- In the Project Tree, open the Analysis Workbench.
Click
(Solve).
