The software saves versions of your objects as you create them, enabling you to return to an earlier stage of an object,
and modify or reuse the object from that stage.
Capture an image of a model. The background is white by default, but you can make it colored or transparent. Arrows
on curves are automatically turned off.
Inspire Studio has four different tool belts to help you quickly access the tools you need for 3D modeling, sketching, creating
PolyNURBS, and rendering. You can use the tool belts with the default configuration of tools or you can customize
the tool belts by adding and removing tools as required.
Inspire Render has three different tool belts to help you quickly access the tools you need to create highly realistic renderings.
You can use the tool belts with the default configuration of tools or you can customize the tool belts by adding and
Change the default units and measure geometry features.
Change the Default Units
In Inspire Studio, the default unit of measurement is centimeters. You can also choose from millimeters, meters, inches, and feet.
Measure Box
Use the Measure Box tool to measure the dimensions of the bounding box for one or more selected objects.
Measure Features
Measure geometry features including a length, an angle, a radius, a diameter, and the dimensions of a bounding box.
