Marine 2022.1 Release Notes
Enhancements
The Marine ribbon is no longer available in HyperWorks.
  • The Stiffener meshing tools are now consolidated with the 1D Mesh tools.
  • Beam→Shell also migrated to the Mesh ribbon and is now called Inflate. The tool is enhanced to support shell beamsection and create properties. A new tool is added to convert standard beamsections to solids.
Feature CAD Property is not useful any more for property realization from metadata and is replaced by Representation > Update in the Part Browser.
  • The only known limitation is that material realization is always a default Steel without considering metdata on the material entity.
  • The "CAD Property" feature is still available in the Model ribbon under the Setup group as backup for material realization.
