Define the Statistics Region
Statistics are taken from a region defined on the curve by range boundaries, which are defined by two points on the selected curve.
View new features for HyperWorks 2022.1.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Plot curves for multiple runs and multiple subcases for a component.
Create and edit curves.
Create macros that produce curves and notes for plots.
Edit curves within a specified range and orientation.
Retrieves individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
Calculates statistics over a specified range on a curve.
Add horizontal and vertical datum lines to plots.
Annotate plots using notes.
Curve scaling, offsets, and axis assignments can be applied to multiple curves using the Move panel.
ON THIS PAGE
ON THIS PAGE
