Front Multi-link
The multi-link suspension derives its name from the fact that it is made up of three or more links. The MotionView multi-link suspension contains four links, and it is generally used on cars and off-road vehicles. This suspension offers flexibility to the designer, since each link’s location can be determined independently.
Figure 1. Front Multi-link Suspension
In conventional designs, the coil spring (or optionally a torsion bar), shock absorber, and jounce bumper act between the one lower link and chassis. Hence the lower link carries most of the load and defines the motion of the lower end of the knuckle. The upper links carry smaller loads and define the motion of the upper portion of the knuckle. The steering motion of the knuckle is controlled by the tie rod and the motion of the steering system. In the vehicle library, the steering systems contain the tie rod.
Model Use
The front multi-link can be used in either a half car or a full vehicle analysis. The default geometry and mass is that of a passenger car or light truck, however the model and data can be revised to reflect any size vehicle, from a large truck to a scale model car.
Note:
  • The wheel body represents the mass and inertia of the tire and the rim.
  • The wheel hub body represents the mass and inertia of other rotating bodies such as a brake rotor, but not the half-shafts if the suspension is driven. The wheel hub and brake rotor have no associated graphics.
  • The wheel and wheel hub parts use the Wheel CG location as the center of gravity.
  • Each body’s Center of Gravity (CG) is estimated from the body’s geometry. The formulas are coded into the point panel and can be seen via the graphical user interface. If more accurate CG locations are available they should be used.
  • The point giving the location of the ball joint between the suspension knuckle and steering tie rod point resides in the steering system.
Tip:
  • A wide variety of combinations of suspensions and subsystems can be built using the Assembly Wizard. You are encouraged to build systems and understand the resulting model using the graphical user interface.
    When building a new suspension model, build the model with all of the optional systems (stabilizer bar, etc) included in the model. Immediately turn off the systems using the Project Browser and run an analysis on the base suspension to ensure it solves properly. As data becomes available for the optional systems; activate those systems and populate them with data.
The image below shows the Project Browser view of the systems in a fully populated front suspension model. The Frnt multilink susp system has four “child” systems.
Figure 3. Browser View of a Front-Half-Vehicle Model Systems and Subsystems Employing a Multi-link Suspension
Points
Points locate the joints and bushings that connect the suspension bodies to one another. The image below shows the principal points for the front multi-link suspension:
Figure 4. Right Side Principal Points – Front Multi-link Suspension
Note: The image above omits the left side of the suspension, points locating body centers of mass, and points that locate the optional subsystems (springs, dampers, bump stops and stabilizer bar) for clarity.
Bodies
The front multi-link suspension is comprised of the bodies shown in the image below:
Figure 5. Right Side Bodies – Front Multi-link Suspension
Note: Optional subsystems may add bodies to the suspension, for example the shock absorber adds two bodies: a shock rod and shock tube. Any bodies added by optional subsystems have been omitted from the image above for clarity.
The wheel hub body has no associated graphics and therefore is not visible in the image above.
Bushings and Joints
The table below describes the bodies, bushings, and joints for the front multi-link:
Note: The table omits the left side joints for clarity.
Label Type Body 1 Body 2 Point Notes
Front Lower Ball Joint Spherical Knuckle Front Lower Control Arm Front Lower Ball Joint When the Compliant option is set to No, the compliance for this joint is turned "Off" and behaves as a pure spherical joint.
Rear Lower Ball Joint Spherical Knuckle Rear Lower Control Arm Rear Lower Ball Joint When the Compliant option is set to No, the compliance for this joint is turned "Off" and behaves as a pure spherical joint.
Front Upper Ball Joint Spherical Knuckle Front Upper Control Arm Front Upper Ball Joint When the Compliant option is set to No, the compliance for this joint is turned "Off" and behaves as a pure spherical joint.
Rear Upper Ball Joint Spherical Knuckle Rear Upper Control Arm Rear Upper Ball Joint When the Compliant option is set to No, the compliance for this joint is turned "Off" and behaves as a pure spherical joint.
Wheel Spindle Revolute Wheel Hub Knuckle Wheel Center
Wheel Hub
Fix Jt
Fixed Joint Wheel Wheel Hub Wheel Center When the Spindle compliance option is set to Yes, the joint type changes to universal.
LCA Front Bush Universal Front Lower Control Arm Subframe, Vehicle Body or Ground Front Lower Control Arm Bush When the Compliant option is set to No, this joint compliance is turned "Off" and behaves as a pure universal joint.
LCA Rear Bush Universal Rear Lower Control Arm Subframe, Vehicle Body or Ground Rear Lower Control Arm Bush When the Compliant option is set to No, this joint compliance is turned "Off" and behaves as a pure universal joint.
UCA Front Bush Universal Front Upper Control Arm Subframe, Vehicle Body or Ground Front Upper Control Arm Bush When the Compliant option is set to No, this joint compliance is turned "Off" and behaves as a pure universal joint.
UCA Rear Bush Universal Rear Upper Control Arm Subframe, Vehicle Body or Ground Rear Upper Control Arm Bush When the Compliant option is set to No, this joint compliance is turned "Off" and behaves as a pure universal joint.
The following image shows the location of the joints and bushings in the suspension:
Figure 6. Right Side Joints and Bushings - Front MacPherson Strut Suspension with Two (2) Piece Lower Control Arm
Similar Suspensions
front MacPherson strut (1pc LCA)
front MacPherson strut (2pc LCA)
Rear SLA (1pc LCA)
Rear SLA (2pc LCA)
