Linear Torque Powertrain
A powertrain based on a linear curve where the torque generated is directly proportional to throttle applied.
View new features for HyperWorks 2022.1.
MotionView is a general pre-processor for Multi-body Dynamics.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences dialog, you can access various MotionView options for your model.
The vehicle library is installed as a part of the normal HyperWorks installation.
Front suspension systems support the wheels in the front with the help of strut rods.
Rear Suspension systems support the rear wheel with the help of a swingarm and coil springs.
Jounce and Rebound bumpers restrict the upward and downward movement of suspension components.
Rider plays an important role in two wheeler dynamics. To capture the effects of rider on a vehicle, it is important to have a good human body multi-body dynamics model.
The driveline transmits the power from the power source to the driving wheel.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
