HyperWorks
HyperWorks
2022.1
  1. Home
  2. Multibody Modeling
  3. Vehicle Modeling
  4. Vehicle Libraries
  5. Two-Wheeler MDL Library
  6. Rear Suspension Systems
    Rear Suspension systems support the rear wheel with the help of a swingarm and coil springs.
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022.1
HyperWorks
  • What's New
    View new features for HyperWorks 2022.1.
  • Get Started
  • Video Tutorials
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
    • MotionView Overview
      MotionView is a general pre-processor for Multi-body Dynamics.
    • Model Browser
    • MotionView Ribbons
    • MotionView CAD Interfacing
    • Flexible Bodies
      MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
    • Preferences Dialog
      From the Preferences dialog, you can access various MotionView options for your model.
    • Vehicle Modeling
      • Build and Analyze Models
      • Vehicle Libraries
        • Car/Small Truck Library
        • Heavy Truck MDL Library
        • Two-Wheeler MDL Library
          • Build a Two-Wheeler Model
            The vehicle library is installed as a part of the normal HyperWorks installation.
          • Front Suspension Systems
            Front suspension systems support the wheels in the front with the help of strut rods.
          • Rear Suspension Systems
            • Motorcycle - Trailing Arm - Twin Shock
            • Motorcycle - Trailing Arm - Mono Shock
            • Scooter - Trailing Arm - Mono Shock
          • Linear Torque Powertrain
            A powertrain based on a linear curve where the torque generated is directly proportional to throttle applied.
          • Jounce and Rebound Systems
            Jounce and Rebound bumpers restrict the upward and downward movement of suspension components.
          • Rider
            Rider plays an important role in two wheeler dynamics. To capture the effects of rider on a vehicle, it is important to have a good human body multi-body dynamics model.
          • Driveline
            The driveline transmits the power from the power source to the driving wheel.
      • Components Library
      • Leaf Spring Modeling
      • Road Modeling
      • Tire Modeling
      • Full Vehicle Events and Altair Driver
      • Road Tools
      • 1D Vehicle System Models
      • Update Model Utility
      • Aerodynamics
    • Tcl/Tk Reference Guide
      Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
    • MDL Reference Guide
    • MotionSolve Reference Guide
    • Templex and Math Reference Guide
    • MotionView Python Reference Guide
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022.1
  1. Home
  3. Vehicle Modeling
  • What's New
  • Get Started
  • Video Tutorials
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
There are two types of rear suspensions in the Two-Wheeler library.
