Body Selection |
Click Open to select a metadata file. All bodies for
which force outputs are requested are listed in the panel's tree structure. You
can select one or more bodies from the tree. For each body selected, all loads
acting on this body are displayed in the Force Selection panel. |
Force Selection |
For each body selected in the Body Selection panel, all loads acting on the
body are shown in a tree structure of the Force Selection panel. You can choose
any number of loads acting on the body. Only the loads that you select are
included in the tabular summary or the Nastran input
deck. |
Time Selection |
This panel allows you to enter or select the time steps for which the loads
should be reported in the tabular summary or included in the Nastran input deck. For those time steps not entered or
selected, the loads are not included in the tabular report or the Nastran input deck. |
Export |
From this panel, you can export a tabular summary or write a Nastran input deck for one or more bodies. |
