Browser Context Menu Options
Run Event Runs the event (exports XML, ADF and submits the solver input file to MotionSolve).
Run All Runs all of the full vehicle events added in the model.
Edit Event Brings up the event setting dialog/Event Editor.
Build Event Exports the solver input file and ADF file to the path provided in the Event Editor dialog.
Edit XML Opens the XML in text editor.
Edit ADF Opens the ADF text editor.
Run XML Submits the solver input file (if generated) to MotionSolve.
