Run Solver - ADAMS and Abaqus
The Run Solver tool allows you to either run the current model or run an existing ADAMS or Abaqus command file generated previously by MotionView.
From the Analyze ribbon, click the Run icon.
| Option | Description | |
| Export Model | Click the save icon to save/export the current model. | |
| Solver Script | Select the solver execution script used to run the model from the drop-down menu. | |
| Export MDL snapshot | Saves a copy of the MDL file. | |
| Export MDL animation file | Writes an .maf file which can be loaded as a model in HyperView. | |
| Select Analysis | Click the drop-down menu to display a list and select an analysis from the model. Select the All option to export the solver deck and solve for each available analysis. | |
| Export | Click Export to execute the solver. | |
