TeimOrbit 2D Road Type: pot_hole
Name of input variable | Unit | Meaning |
depth | length | Depth of pot-hole. |
start | length | Start of pot-hole (travel distance). |
length | length | Length of pot-hole. |
View new features for HyperWorks 2022.1.
MotionView is a general pre-processor for Multi-body Dynamics.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences dialog, you can access various MotionView options for your model.
To specify and evaluate road excitation, COSIN/road uses one central subroutine evrmr (COSIN environmental models: road main routine).
If COSIN/road detects the road file in COSIN/io format, it first tries to read certain information common to all road types within this format (see Data Common to all COSIN/io Style Road Types).
If COSIN/road recognizes the road data file is in TeimOrbit format (typically, the file name extension is rdf), it branches into the respective reading and evaluation routines.
If the road data file is in COSIN/io format, but does not contain the data block $road_type, it is interpreted as a COSIN road track file.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
