HyperWorks
HyperWorks
2022.1
  1. Home
  2. Design Space
  3. Tutorials
    View tutorials for design space workflows.
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022.1
HyperWorks
  • What's New
    View new features for HyperWorks 2022.1.
  • Get Started
  • Video Tutorials
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
    • Voxel Meshing
      Voxel meshing fills an enclosed volume with voxels (hexas) of a pre-defined size.
    • Set Up Design Space Libraries
      A Design Space library is an automotive focused library that can be used to rapidly create full vehicle architecture concept models.
    • Edit and Position Primitives
      Edit and position nondesign parts or subsystems in your design space.
    • Envelope Volumes
      Extract an envelope by sweeping a volume.
    • Connect Design Spaces to Structures with RBE3s
      The voxel workflow is used to generate design spaces for topology optimization. RBE3s are used to connect the design space to the structure.
    • Connect Design Spaces to Structures with Tie Contacts
      Design spaces can also be connected to structural elements using tie-based contacts.
    • Tutorials
      • Design Space: Global Voxel Mesh Creation
      • Design Space: Local Voxel Mesh Creation
      • Design Space: Edit a Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022.1
  1. Home
  2. Design Space
  3. Tutorials
  • What's New
  • Get Started
  • Video Tutorials
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
Tutorials
