View new features for HyperWorks 2022.1.
Voxel meshing fills an enclosed volume with voxels (hexas) of a pre-defined size.
A Design Space library is an automotive focused library that can be used to rapidly create full vehicle architecture concept models.
Edit and position nondesign parts or subsystems in your design space.
Extract an envelope by sweeping a volume.
The voxel workflow is used to generate design spaces for topology optimization. RBE3s are used to connect the design space to the structure.
Design spaces can also be connected to structural elements using tie-based contacts.
View tutorials for design space workflows.
