Design Space: Global Voxel Mesh Creation
Before you begin, copy the file(s) used in this tutorial to your working
directory:
- Start HyperWorks 2022.1.
Open the Design_Space_Topology.hm model file.
Figure 1. - Click the Design Space ribbon.
Click the Global tool to create global voxel mesh.
Figure 2. -
Click
on the guide bar and set the voxel size to 30.
Leave the other options as default.
Figure 3. -
Click
next to Include, select auto 1, and then click OK.
Alternatively, you can also pick the components to be included by selecting them from the modeling window.
Click
next to Exclude, select all the components besides auto 1, and then click OK.
Similarly, you can also pick components directly from the modeling window.
- Optional:
Define a symmetry plane.
- Click Symmetry on the guide bar.
- Right-click in the modeling window and select Create New.
Select the node shown below as the origin of the vector tool.
Figure 4. -
Input 0,1,0 in the X, Y and Z fields
respectively to orient the vector then click
The direction of vector tool decides which is the parent side – in this case, the left hand side is the parent since the vector tool is pointing to the right.
Figure 5.
Click Create on the guide bar to
generate the voxel mesh.
Figure 6.
