FMIN_SLSQP
Utility/Data Access SubroutineSLSQP optimizer is a sequential least squares programming algorithm for nonlinear, constrained gradient-based optimization. It supports both inequality and equality constraints.
Definition
This function is also documented in Scipy at scipy.optimize.fmin_slsqp.
Use
The utility can be called by any user-defined subroutine written in Python.
fmin_slsqp(func, x0, eqcons=[], f_eqcons=None, ieqcons=[], f_ieqcons=None, bounds=[], fprime=None, fprime_eqcons=None, fprime_ieqcons=None, args=(), iter=100, acc=1e-06, iprint=1, disp=None, full_output=0, epsilon=1.4901161193847656e-08)
Attributes
- func
- A function that can be called by Python that evaluates the objective function that is to be minimized.
- X0
- The initial guess for the independent variables.
- eqcons
- A list of functions of length N that specify all the equality constraints that FMIN_SLSQP must maintain. In a successfully optimized problem, FMIN_SLSQP will ensure that eqcons[i](x,*args) == 0, i=1…M, where M=len(eqcons)
- f_eqcons
- f_eqcons is a function that can be called by Python. This function returns a 1-D array of floats that must equal 0.0 in a successfully optimized problem. f_eqcons has the form: f(x, *args)
- ieqcons
- A list of functions of length N that specify all the inequality constraints that FMIN_SLSQP must satisfy. In a successfully optimized problem, FMIN_SLSQP will ensure that ieqcons[i](x,*args) >= 0, i=1…M', where M'=len(ieqcons)
- f_ieqcons
- f_ieqcons is a function that can be called by Python. This function returns a 1-D array of floats that must be greater than or equal 0.0 in a successfully optimized problem.
- bounds
- A list of types specifying the lower and upper bound for each independent variable. It has the form: [ (xl0,xu0), (xl1,xu1), ... (xlN,xuN)]
- fprime
- A function that evaluates the partial derivatives of func with respect to the independent variables.
- fprime_eqcons
- A function that can be called by Python. This function returns the Jacobian matrix of the equality constraints in an M x N array of floats.
- fprime_ieqcons
- A function that can be called by Python. This function returns the Jacobian matrix of the equality constraints in an M' x N array of floats.
- args
- These are the additional arguments that are passed to func, fprime, fprime_eqcons and fprime_ieqcons.
- iter
- This specifies the maximum number of iterations available to FMIN_SLSQP to obtain a minimum.
- acc
- This is the accuracy to which a solution is desired.
- iprint
- This defines the verbosity of the diagnostics generated by FMIN_SLSQP.
- iprint <= 0 : Silent operation.
- iprint == 1 : Print summary upon completion (default).
- iprint >= 2 : Print status of each iteration and summary.
- disp
- This defines the verbosity of the diagnostics generated by FMIN_SLSQP. When specified, disp overrides the iprint interface.
- full_output
- If false, it returns only the minimizer of func (default). Otherwise, it returns the output final objective function and summary information.
- epsilon
- The step size for finite-difference derivative estimates.
Output
- out
- The final minimizer of func.
- fx
- If full_output is true, fx will contain the final value of the objective function.
- its
- If full_output is true, this will contain the number of iterations taken.
- imode
contain the exit mode from the optimizer. The values of
imode have the following significance:
- -1
- Gradient evaluation required.
- 0
- Optimization terminated successfully.
- 1
- Function evaluation required.
- 2
- More equality constraints than independent variables.
- 3
- More than 3*n iterations in LSQ subproblem.
- 4
- Inequality constraints incompatible.
- 5
- Singular matrix E in LSQ subproblem.
- 6
- Singular matrix C in LSQ subproblem.
- 7
- Rank-deficient equality constraint subproblem HFTI.
- 8
- Positive directional derivative for linesearch.
- 9
- Iteration limit exceeded.
- smode
- If full_output is true, this will contain a message describing the exit mode from the optimizer.
- FMIN_SLSQP is the interface function for the SLSQP optimization function originally implemented by Dieter Kraft. SLSQP is a Sequential, Least SQuares Programming algorithm.
- Optimization can be done in MotionSolve through the use of a CONSUB user subroutine together with FMIN_SLSQP. This can be used for model identification or mechanism optimization. The CONSUB may be written in Fortran/C/C++ or Python/MATLAB scripts.
