SET_DAE_ERROR
Utility/Data Access SubroutineThe SET_DAE_ERROR utility subroutine sets the integration error tolerance for the DAE integrator DSTIFF.
- Fortran Calling Syntax
- CALL SET_DAE_ERROR(ERROR)
- C/C++ Calling Syntax
- c_set_dae_error(error)
- Python Calling Syntax
- py_set_dae_error(error)
- MATLAB Calling Syntax
- m_set_dae_error(error)
Attributes
- ERROR
- Double precision
Complete Definition
The SET_DAE_ERROR is a function style subroutine which can be used in a TUNSUB subroutine to set the integration error tolerance for the DAE integrator DSTIFF and for FIM_D. Using this function, the integration error tolerance can be modified spontaneously as per the simulation needs.
This function is typically used to improve accuracy or performance of the multibody simulation.
Please see TUNSUB for a GETNUMID usage example for SET_DAE_ERROR.
