SET_ATTRIBUTE
Utility/Data Access SubroutineThis subroutine modifies the attribute accessed by the last MODFNC or MODSET call.
Use
This subroutine must be preceded by MODFNC or MODSET calls. It modifies the same Element/ID referenced by the preceding MODFNC or MODSET until another MODFNC or MODSET with a different Element ID is called. You can have multiple SET_ATTRIBUTE calls after a preceding MODFNC or MODSET call.
- Fortran Calling Syntax
- SUBROUTINE SET_ATTRIBUTE(INPUT, INFO)
- C/C++ Calling Syntax
- c_set_attribute(input, info)
- Python Calling Syntax
- info = py_set_attribute(input)
- MATLAB Calling Syntax
- info = m_set_attribute(input)
Attributes
- INPUT
- [string]
- INFO
- [integer]
