SET_DAE_HMAX
Utility/Data Access SubroutineThe SET_DAE_HMAX utility subroutine sets the maximum step size that the DAE integrator DSTIFF is allowed to take.
- Fortran Calling Syntax
- CALL SET_DAE_HMAX (HMAX)
- C/C++ Calling Syntax
- c_set_dae_hmax(hmax)
- Python Calling Syntax
- py_set_dae_hmax(hmax)
- MATLAB Calling Syntax
- m_set_dae_hmax(hmax)
Attributes
- HMAX
- Double precision
Complete Definition
The SET_DAE_HMAX is a function style subroutine which can be used in a TUNSUB to set the maximum time step size DAE integrator DSTIFF. Using this function, the step size can be modified on the fly as per the simulation needs.
This function is typically used to improve accuracy or performance of the multibody simulation.
Please see TUNSUB for a GETNUMID usage example for SET_DAE_HMAX.
