Pad Size
Check the size of a certain component’s pad
- Pad Size Checking
- Item Name: Specify the item name.
- Component Group: Set target component from component group list.
- Minimum Size: Set minimum pad size.
- Minimum Width: Set minimum pad width.
- Only Pad Size Check: Report pad X/Y size into results file for whole
target pads.
