Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use the Plot RBE/MPC tool to plot RBE and MPC considering a RBE3/MPC with a given weighting factor where the nodes
are written in a certain displacement coordinate system.
Use the Dataname Viewer tool to display either scalar or new marker plots on elements/nodes associated to their data
names and attributes. For elements the link can be extended directly to the associated properties and materials.
Review Orientation Use the Orientation Review tool to display/review and modify frequently used coordinate systems used in CAE analysis.
Plot RBE/MPC
Use the Plot RBE/MPC tool to plot RBE and MPC considering a RBE3/MPC with a given weighting factor where the nodes are written in a certain displacement coordinate system.
Dataname Viewer
Use the Dataname Viewer tool to display either scalar or new marker plots on elements/nodes associated to their data names and attributes. For elements the link can be extended directly to the associated properties and materials.
Control IDs from Selection
Use the Control IDs from Selection tool to create a list of selected nodes/elements, review and control IDs.
