Add a Note
Add a note to a point on a curve.
                From the Line Chart, Bar Chart, or Complex Chart ribbon, click the
                        Notes tool.
                 Figure 1. Figure 1.
                Hover over the curve to locate the coordinates to add the note to. Once the
                    point value is displayed, left-click to add the note to the curve.
                Add a note to the window by clicking anywhere in the plot window. The note is displayed as View Note in this instance.
                Select the note's border, right-click and select Edit to
                    display the Entity Editor. Use this to edit the note's
                    properties.
                 Figure 2. Entity Editor - NotesTip: You can also use the Plot Browser to edit the note. Click on the note from the plot window to display its attributes in the Plot Browser.Tip: See Notes for more information on editing the note attributes. Figure 2. Entity Editor - NotesTip: You can also use the Plot Browser to edit the note. Click on the note from the plot window to display its attributes in the Plot Browser.Tip: See Notes for more information on editing the note attributes.
