HyperWorks
HyperWorks
2022.2
  1. Home
  2. Plot Data
  3. Bar Chart
  4. Define
    Edit existing bar charts individually and add new bar charts to the current plot.
  5. Use Math as a Data Source
  • What's New
  • Get Started
  • Video Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022.2
HyperWorks
  • What's New
    View new features for HyperWorks 2022.2.
  • Get Started
  • Video Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
    • Working with Plots
      Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
    • Line Chart
    • Bar Chart
      • Define
        • Use a File as a Data Source
        • Edit a Curve with File as the Data Source
        • Use Math as a Data Source
        • Use Values as a Data Source
        • Add or Delete a Row to the Values Table
        • Insert Data Point Values
      • Datums
        Add horizontal and vertical datum lines to plots.
      • Notes
        Annotate plots using notes.
    • Complex Chart
    • Polar Chart
    • Vector Chart
    • Radar Chart
    • 3D Chart
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022.2
  1. Home
  2. Plot Data
  3. Bar Chart
  4. Define
  • What's New
  • Get Started
  • Video Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
  1. From the Bar Chart Define panel, select Data Source > Math.
  2. Define the vector using the curve calculator to create a mathematical expression.
