View new features for HyperWorks 2022.2.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Edit existing curves and add new curves to the current plot.
Add horizontal and vertical datum lines to plots.
Displayed immediately upon curve selection, the tip-to-tail function calculates and draws the tip-to-tail function based on the current plot.
