Add a Note to a Plot Macro
- From the Math panel, select a macro from the macro list.
- Click Edit.
- Select the Note tab.
- Activate the Create note check box.
- Enter text in the Text box.
- Select Window, View, Existing curve, Coordinate, or Curve created by this macro from the Attach To combo box.
                Enter the data pertaining to the following:
                - Existing curve
- Curve and point to which the note is attached.
- Coordinate
- X and Y coordinates to which the note is attached.
- Curve created by this macro
- Point to which the note is attached.
                Enter X and Y coordinates to
                    position the note center.
                If you are plotting complex data, select Real/Imaginary or Phase/Magnitude for the Y coordinate. You can use the functions from the Functions list.
- Click Close.
