Scale X or Y Vectors
- Select the curves to be scaled from the list.
 - Enter a multiplier in the text box.
 - Activate the X scale or Y scale check box.
                Click Apply to accept the new scaling values.
                The selected curves are scaled along the horizontal or vertical axis.Note: You can scale an x or y vector by placing a multiplier in the text box before or after the correct parameter field. For example:
Previously: saefilter(p1w1c1.x, p1w1c1.y, 60)
Currently: saefilter(p1w1c1.x*.001, p1w1c1.y*.001, 60)
