Produce S. Dietz's "frequency response mode" for MB Analysis
                Perform a normal analysis without constraint
                    (free-free).
                Read results.- m
- System mass matrix (Lumped mass).
- Xn
- Free-Free normal modes including the rigid body modes
                                    (Xn=[Xr,X1,X2,....,Xk]).
- Dn
- Diagonals are the eigenvalues associated with Xn.
                Perform a "special" static analysis without
                    constraint in FE:
                ( k - l * m ) * Xf = Fawhere,- k
- System stiffness matrix.
- l
- A scalar, usually half of the first nonzero frequency of the free-free normal analysis in step 1.
- m
- Fa
- Attachment forces at junction nodes, not necessarily unit loads.
 Read results.- Xf
- The "frequency respond mode" associated with l and Fa (the displacement from the "special" static analysis).
                Form modal stiffness matrix KHAT as:
                KHAT= | Dn Xn'*Fb | | Fb'*Xn Xf'*Fb |where Fb is the balancing force and is defined as:Fb = Fa + l*m*XfForm modal mass matrix MHAT as:MHAT=X'*m*Xwhere X is the combined mode:X=[Xn Xf]
                Orthogonalize X by solving the following eigen problem:
                KHAT*N=MHAT*N*DIf X is not independent, then one of the following occurs:- The eigenvalues/vectors are complex
- Some highest eigenvalues are infinite
- Extra zero eigenvalue rigid body modes
 In either case, the corresponding modes can be filtered out so this step removes dependent modes as well.
                Transform X to orthoginalized modes Y:
                Y=X*NThis is the mode set of rigid body modes, free-free normal modes, and S.Dietz's "frequency response mode" modes. The generalized mass and stiffness matrix are:M=N'*MHAT*N=I K=N'*KHAT*N=DY, D, and m are used to calculate the flexible MB input file.
