Create Derived Load Cases
Create derived load cases in the form of linear super-position and/or envelope.
- From the Post ribbon, click the satellite icon  that appears when you hover over the
                            Results tool. that appears when you hover over the
                            Results tool.
- Right-click on a result or load case entity in the Results Browser and select Create Derived Loadcase.
Figure 1. Linear Superposition
Figure 2. Envelope
Envelope can be either min or max, and it requires, where available, the definition of the relevant metric, for quantities such as vector and tensor.
Each newly created derived load case (DLC) is appended to the list and can be reviewed using the context menu. DLCs are then available in all of the other result tools.
Figure 3.
