Apply tension to a seatbelt for testing using the tensioning option.
            The tensioning option in the Seatbelt entity context allows you to simulate the
                tensioning process on a seatbelt. You can define the tensioning force, contact
                friction, and the pulling of the belt (start or end).
                Right-click the appropriate seatbelt entity and select
                        Tensioning from the context menu.
- Optional:
                Set options as necessary by clicking the  menu. menu.
                On the guide bar, click the
                        Tension button.
                This will start the tension process. A status bar in the lower left corner informs you of the evolution of the
                    process.
                From the microdialog, use the Cut
                        End slider to cut the tensioned belt at the initial end or start
                    location.
                Click Update Nodes to update the seatbelt with the shape
                    of the selected simulation step.
