View new features for HyperWorks 2022.2.
Collectors are named organizational containers for collected entities. Collected entities are nameless entities which must reside within one, and only one, collector. Collected entities are mutually exclusive to a collector.
Include files enable solver decks to be split into separate files for organizational purposes, and provide a mechanism to include these files in a master solver beck, typically using an include statement.
SolverSubmodels allow you to manage ID offsets as well as define transformations on solver entities or Include files.
Assemblies collect and organize sub-assemblies and components into hierarchical data structures which are intended to reflect the data structure of the product being modeled.
Bags collect and organize entities.
Multibodies collect and organize ellipsoids, multibody planes, and multibody joints and are typically used in multi-body analysis.
Entities which are given a name but are not collected or organized into containers.
Entities used for morphing the shape of FE model.
Entities used to set up optimization problems.
Control card entities create solver control cards such as results file I/O options, CPU and memory limits, and others.
Undefined entities are entities that will not be written to the solver deck.
The encryption of solver entities is used to translate entity data into an undisclosed language.
Element property and material assignment rules are based on the current user profile (solver interface).
Supported cards organized by solver.
ON THIS PAGE
ON THIS PAGE
