Points and Nodes
Learn about creating, editing, and extracting points and nodes.
View new features for HyperWorks 2022.2.
Explore the tools used to create geometry.
A point is a zero-dimensional geometric entity.
Nodes are the most basic finite element entity. A node represents a physical position on the structure being modeled.
Use the Create Points/Nodes tool to create and edit points/nodes on geometry surfaces and lines or in space. Points and nodes can be used to establish reference locations for geometry construction and meaningful snap locations for use with other tools.
Use the Extract Points/Nodes tool to interpolate and divide an edge or line, and find the center of an arc, fillet, or multiple curve segments.
Create and edit circles and rectangles with the Shapes tool.
A line represents a curve in space and is not attached to any surface or solid. A line is a one-dimensional geometric entity.
Detect, review, and manage geometric holes, fillets, flanges, and logos.
A surface represents the geometry associated with a physical part. A surface is a two-dimensional geometric entity that may be used in automatic mesh generation.
Solids are closed volume of surfaces that can take any shape. Solids are three-dimensional entities that can be used in automatic tetra and solid meshing.
Use the Ruled tools to create surfaces/solids by interpolating lines and surfaces either linearly or smoothly.
A face is a single Non-uniform Rational B-Spline (NURBS) and is the smallest area entity. It has a separate underlying mathematical definition, specified when it was created.
Use the Drag/Spin tool to drag and spin lines, surfaces, and nodes in order to create surfaces or solids.
Use the Offset tool to offset surfaces, solids, or lines.
Use the Midlines tool to create midlines from existing lines, surface edges, or tube solids.
Extract the midsurface of thin solids, and review and edit midsurface plates.
Explore the tools used to edit geometry.
Clean up problematic areas on geometry.
ON THIS PAGE
ON THIS PAGE
