Preserve Edges
Use the Preserve Edges tool to ensure that specific component edges and feature lines do not accidentally get discarded during auto cleanup or batch meshing.
View new features for HyperWorks 2022.2.
Explore the tools used to create geometry.
Explore the tools used to edit geometry.
Clean up problematic areas on geometry.
Use the Defeature tool to automatically find, review, and defeature holes and other non-essential features.
Use the Surface Repair tools to find, review, and fix any geometric errors in the model's surfaces.
Fix gaps between stitched edges and vertices to make the actual geometry of the surfaces consistent with the model topology.
Find intersections and penetrations between geometric surfaces and solids.
ON THIS PAGE
ON THIS PAGE
