Translators
Translators are utilities that are run from the command line of the operating system to convert various types of results files into a format that the program can read. A table of the translators supplied with the programs appears below. Since the program can read HyperMesh binary results files, the entire set of HyperMesh results translators is included.
To run a translator, type the name of the translator, desired command line options, the name of an input file, and the name of an output file. To view usage notes on a particular translator, type the name of the translator at the command prompt and press enter.
| Translator | Converts | To |
| fatigueprep | ADAMS .res file | .dac files |
| fil2mrf | Abaqus .fil file | Altair multibody result file for animation in HyperView Altair Binary Format for plotting in HyperGraph Tabulated ASCII file |
| flexprep | Nastran punch files, via ADAMS DMAP, alters into
                  an Altair H3D file. ADAMS MNF files Altair H3D files | Altair H3D file Altair H3D file ADAMS MTX file |
| hgares | ADAMS formatted .res files | Altair Multibody Result File for animation in HyperView Altair Binary File for plotting in HyperGraph Tabulated ASCII file |
| hgreq | ADAMS request file | Altair Binary Format |
| mvg | STL, Wavefront, hmascii | Altair .g graphic file |
