Permas Solver Interface
Overview of the Permas interface.
- Read in a Permas .dat file
- Read and write .gz files
- Specify linear, nonlinear static and frequency analyses
- Preview and edit Permas cards
- Output a HyperView .h3d file for post-processing
HyperWorks supports Permas .dat files for direct import. Permas .uci command files are supported from version 2019.1.
The Permas interface supports names up to 40 characters in length.
MPC ID Pools
The HyperWorks Permas interface allows multipoint constraints (MPC) to use the same ID as other elements, such as beams, shells or solids within HyperWorks. In other words, selected elements and MPCs can use different “ID pools.”
| HyperWorks entity | MPC type |
| rigid | ASSIGN |
| RIGID | |
| SAME | |
| JOIN | |
| rbe3 | WLSCON |
| IQUAD | |
| ITRIA | |
| equation | GENERAL |
| group | ISURFACE |
| WLSSURFACE | |
| WLDSURFACE |
While rigid and rbe3 elements use the same ID pool in HyperWorks, equations and groups have separate ones. Thus, it is possible to create duplicate IDs for MPCs as well. To resolve this, during export, a solver option is available in the Export Options dialog to renumber MPCs if duplicate IDs are present. This option will check for the highest rigid/rbe3 ID and renumber equation entities accordingly. Groups are not included in the renumbering functionality as contact IDs would be affected by renumbering.
Due to the mapping scheme explained above, it is possible to import MPCs with duplicate IDs; for example, MPC JOIN and GENERAL equation and groups although Permas does not allow it.
Before working with your model, ensure that the Permas user profile is loaded. The user profile provides a customized HyperWorks environment for working with Permas.
