Extension XML
Format of customized extension.xml files.
XML Overview
The extension manager allows for additional plugin features to be loaded into the application through .xml, scripts, and resources. The extension .xml structure consists of a single top file which references all of the required resources by relative path of the extension folder.
Tags
section
- Attributes
- name
- Children
- entry
entry
- Attributes
- name, value
- Children
- None
Options
profile
Supported HyperWorks client (HyperMesh, HyperView, HyperGraph, and so on)
name
Unique identifier for the extension
displayName
Name displayed in the extension manager
version
Version displayed in the extension manager
script
Relative path to the Python script invoked on load
resources
Relative path to the folder containing images and other resource files
Defaults to resources folder
workflowhelp
Relative path to the workflowhelp .xml file
minProductVersion
Minimum HyperWorks version required for the extension to be loaded
version
Version of the extension
supportedClient
Application for which the extension is supported (HyperWorks Desktop, Inspire, and so on)
documentation
Relative path to the help .html file which will be loaded using the description link
contexts
Relative path to the folder containing context scripts
Defaults to context folder
tclscript
Relative path to the .tcl script invoked on load
ribbonxml
Relative path to the ribbon .xml file
toolbars
Relative path to the directory which contains the toolbar.xml file
- Example XML
                            <section name="Extension"> <entry name="name" value="Postprocessing in HV, HG, MV" /> <entry name="displayName" value="Postprocessing in HV, HG, MV" /> <entry name="resources" value="images" /> <entry name="workflowhelp" value="contexts/workflowhelp.xml" /> <entry name="minProductVersion" value="HWX Version 2022" /> <entry name="version" value="2.0" /> <entry name="supportedClient" value="HyperWorksDesktop" /> <entry name="script" value="pyscript.py" /> <entry name="documentation" value="documentation/index.html" /> <section name="profile" value="HyperMesh"> <entry name="ribbonxml" value="hm/hm-ribbon.xml" /> <entry name="tclscript" value="hm/hm-init.tcl" /> <entry name="toolbars" value="hm/toolbars" /> <entry name="contexts" value="hm/contexts" /> </section> <section name="profile" value="HyperView"> <entry name="ribbonxml" value="hv/hv-ribbon.xml" /> <entry name="tclscript" value="hv/hv-init.tcl" /> </section> <section name="profile" value="HyperGraph"> <entry name="ribbonxml" value="hg/hg-ribbon.xml" /> <entry name="tclscript" value="hg/hg-init.tcl" /> <entry name="toolbars" value="hg/toolbars" /> </section> <section name="profile" value="MotionView"> <entry name="ribbonxml" value="mv/mv-ribbon.xml" /> <entry name="tclscript" value="mv/mv-init.tcl" /> <entry name="toolbars" value="mv/toolbars" /> </section> </section>
