Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Displays the data contained in the selected TableView
cell.
From the Table ribbon, click the Edit tool to
display the edit bar at the top of the TableView window.
Figure 1. Edit icon
Click a cell to
display the cell and its content in the edit bar, where you can edit the text or
Templex expression. Click the
Edit tool again to hide the edit bar.
Figure 2. Cell B3 selected, cell highlighted and content displayed in Edit
bar
The Edit tool supports
multiple lines of data. Press Alt + Enter to add a line break to a single cell.
Note: A cell can evaluate only one Templex expression
starting with an equal sign, “=”; multiple lines are not supported even when the
other lines contain only strings.
Evaluate Mode
Change cell data to evaluated or unevaluated mode using the View toolbar Evaluate
icon, . Templex expressions are
visible in the cell when you click the Evaluate icon.
