Mechanism Browser
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
You can undo and redo actions made in the Mechanism Browser using the Undo and Redo commands on the Restore toolbar.
| Column | Description |
| Entity | Lists the mechanism, joints, bodies, and constraints in your model. |
| ID | Displays the mechanism, joints, bodies, and constraints IDs. |
| Type | Displays the joint or constraints type. |
| Color | Displays the joint and body entity colors. Body color is different from the component color set-up in the Model Browser. The body color is activated when a body is in Review mode. |
| Lock level | Displays the lock level of a joint (green = free joint, yellow = locked joint). |
Entity Editor
The Entity Editor is used to assign, modify and quickly view the attributes defined inside Mechanism Browser entities.
For example, once you create a new body or select a body in the browser, the Entity Editor opens and displays the bodies corresponding attributes, which you can view and modify.
Figure 3.
Context Menu
Supported Entities
 ) is the root of
                the hierarchy in the Mechanism Browser. To create a Mechanism,
                right click in the Mechanism Browser and select  from the context menu. A mechanism is defined
                by the following entities:
) is the root of
                by the following entities:- Bodies ( ) define
                        a kinematic assembly made of FE parts or nodes, which can be selected in the
                            Entity Editor. To create a body, right-click on
                        the Mechanism and select  from the context menu. ) define
- Joints ( ) define
                        the kinematic relationship between two bodies (for the following joint
                        types: Ball, Cylinder, Revolute, Slider) or three bodies (for the
                        DoubleSlider joint). To create a joint, select two bodies to connect in the
                        browser, then right-click and select Connect from the
                            context menu. For the DoubleSlider joint, the
                        third body has to be defined in the Entity Editor. ) define
- Constraints ( ) define
                        kinematical constraints on a body at a specified node or point
                        location. ) define
                        location.
Supported Keywords Exported in Solver Deck
The mechanism information is embedded in the input deck using keywords following the /END (for Radioss), *END (for LS-DYNA), ENDDADTA (for OptiStruct/Nastran) and *END STEP (for Abaqus).
- $ASSEMBLY defines a body with the following
                            attributes:- Assembly ID
- Assembly name
- Number of part sets and related set IDs
- Number of parts and related part IDs
- Number of node sets and related set IDs
- Locked degrees of freedom
- Optional local coordinate system
- $CONNECTION defines a joint between assemblies with the
                        following attributes:- Connection name
- Assembly ID #1
- Assembly ID #2
- Connection position (defined by Node IDs or connection position coordinates)
- Joint limits in + and - directions
- Current joint distance/angle value
- Lock level
- Assembly ID #3 (for the Double Slider only)
- Scale factors for relative displacement between Assembly #3 and Assembly #1 and #2
- $POSITION defines, for a stored position, the position
                        information for the mechanism’s assemblies with the following attributes:- Position name
- Assemblies position matrixesNote: The Reference and Initial positions should never be deleted inside the mechanism.
- The following connection keywords can be defined depending on the type of
                        joint created:- $CONNECTION_PIN defines a ball joint
- $CONNECTION_HINGE defines a revolute joint
- $CONNECTION_CAM defines a cam joint
- $CONNECTION_LINE defines a cylindrical joint, or a double slider joint if assembly ID #3 is defined or a slider joint has the #HM_SLIDER_JOINT comment defined before the name of the connection
Create Mechanisms
Create a mechanism for Abaqus, OptiStruct, and Nastran profiles.
Mechanisms are created using a manual approach only.
Modify the Position of Mechanisms
Modify the Position of Joints
- In the Mechanism Browser, right-click on a joint and select Move from the context menu.
                Modify the position of the joint.
                - In the graphics area, click-and-drag the manipulator.
 Figure 9.
- In the Entity Editor, modify the Current angle
                        of the joint.
 Figure 10.
- Change the Increment value to control the increments of the operation.
