Media Browser
Use the Media Browser to search, display, and edit media file data within the current HyperWorks session.
View new features for HyperWorks 2022.2.
Learn the basics of working with browsers.
The Entity Editor enables you to quickly edit entities in a model and correctly setup solver information.
Use the Entity State Browser to set various states for entities in a model.
Use the Demo Browser to quickly access and open demo model files available in the installation.
In the Mask Browser, set the mask/unmask state for entities at the entity configuration level.
The Model Browser is a central part of HyperWorks that allows you to get an overview, edit, and control the display of all contents of a model.
Use the Plot Browser to search, display, and edit plot data within the current HyperWorks session.
The Reference Browser enables you to quickly understand complex relationships between different entities that constitute the model.
Use the Results Browser to view the results data model structure while providing find, display, and editing control of entities within the current HyperWorks session.
The Solver Browser provides a solver centric view of the model structure in a flat, listed tree structure.
Use the Table Browser to search, display, and edit TableView file data within the current HyperWorks session.
Use the Text Browser to search, display, and edit text file data within the current HyperWorks session.
The Utility menu contains options that allow you to customize the standard interface to include function buttons, radio options, and text that have HyperWorks-supplied and user-defined macros associated with them.
ON THIS PAGE
ON THIS PAGE
