Run Model Quality Checks on Selected Entities
Use the Model tool to quickly run solver-related checks on all/selected entities in the model and apply auto-correction where defined.
View new features for HyperWorks 2022.2.
Use the Model Checker to configure solver validity checks, modify and create new checks and corrections, and fix modeling issues in an automatic or manual way.
Use the Mass tool to calculate the mass, center of gravity (COG), and moments of inertia (MOI) of the model.
ON THIS PAGE
The entities that do not meet the solver requirements are flagged under the respective checks in the Model Checker.
ON THIS PAGE
