/CHECK/RFILE/OFF
Block Format Keyword Option to stop the Starter after model check. The domain decomposition calculation and writing of the restart files (.rst) is not done.
This reduces the time to run for the Starter model to run when doing a model check.
| /CHECK/RFILE/OFF | |||||||||
- Alternatively, the
writing of the restart file can be turned off by using the Starter
executable command line option
-check=norst.
