/PROP/TYPE4 (SPRING)
Block Format Keyword Defines spring property with one translational DOF. This spring accounts for nonlinear stiffness, damping and different unloading. Deformation based failure criteria is available.
/PROP/TYPE4/prop_ID/unit_ID or /PROP/SPRING/prop_ID/unit_ID
prop_title
Mass       sens_ID Isflag Ileng
K1 C1 A1 B1 D1
fct_ID11 H1 fct_ID21 fct_ID31 fct_ID41   δ min 1 δ max 1
F1 E1 Ascale1 Hscale1
Definition
prop_ID Property identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
prop_title Property title.
Mass Mass.
(Real)
[ kg m ]
sens_ID Sensor identifier used for spring activation or deactivation.
= 0
Spring is active.
(Integer)
Isflag Sensor flag. 2
=0
Spring element activated when sens_ID activates and cannot be deactivated.
=1
Spring element deactivated when sens_ID activates and cannot be activated.
=2
Spring elements are activated, or deactivated state matches the sensor state and can switch back and forth. The spring initial length ( l 0 ) is based the spring length at the activation time.
(Integer)
Ileng Input per unit length flag.
=0
Spring properties are input as explained in the definition table.
=1
Spring mass and inertia input are per unit length. Spring stiffness is a function of engineering strain. 3 4
(Integer)
K1 If f c t _ I D 11 = 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGMbGaam 4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaaGymaiaaigda aeqaaOGaeyypa0JaaGimaaaa@401A@ : Linear loading and unloading stiffness.
If f c t _ I D 11 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGMbGaam 4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaaGymaiaaigda aeqaaOGaeyiyIKRaaGimaaaa@40DB@ : Only used as unloading stiffness for elasto-plastic springs.
(Real)
[ N m ]
C1 Damping.
(Real)
[ Ns m ]
A1 Nonlinear stiffness function scale factor.
Default = 1.0 (Real)
[ N ]
B1 Logarithmic rate effects scale factor.
(Real)
[ N ]
D1 Logarithmic rate effects scale factor.
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
fct_ID11 Function identifier defining f ( δ ) . 4
= 0
Linear spring with stiffness K1.
If H1 =4: Function defines upper yield curve.
If H1 =8: Function is mandatory and defines the force versus spring length.
(Integer)
H1 Spring Hardening flag for nonlinear spring.
=0
Elastic spring.
=1
Nonlinear elastic plastic spring with isotropic hardening.
=2
Nonlinear elastic plastic spring with uncoupled hardening.
=4
Nonlinear elastic plastic spring with kinematic hardening.
=5
Nonlinear elastic plastic spring with nonlinear unloading.
=6
Nonlinear elastic plastic spring with isotropic hardening and nonlinear unloading.
=7
Nonlinear elastic spring with elastic hystersis.
=8
Nonlinear elastic spring with total length function.
(Integer)
fct_ID21 Function identifier defining force as a function of spring velocity, g ( δ ˙ ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbWaae WaaeaacuaH0oazgaGaaaGaayjkaiaawMcaaaaa@3A83@ .
(Integer)
fct_ID31 Function identifier.
If H1 =4: Defines lower yield curve
If H1 =5: Defines residual displacement versus maximum displacement
If H1 =6: Defines nonlinear unloading curve
If H1 =7: Defines nonlinear unloading curve
(Integer)
fct_ID41 Function identifier for nonlinear damping h ( δ ˙ ) .
(Integer)
δ min 1 Negative failure displacement.
Default = -1030 (Real)
[ m ]
δ max 1 Positive failure displacement.
Default = 1030 (Real)
[ m ]
F1 Abscissa scale factor for damping functions for g MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374C@ and h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374C@ .
E1 Ordinate scale factor for the damping function g MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374C@ .
(Real)
[ N ]
Ascale1 Abscissa scale factor for the stiffness function f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374C@ .
[ m ]
Hscale1 Ordinate scale factor for the damping function h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbaaaa@374C@ .
Example (Seatbelt)
#RADIOSS STARTER
/UNIT/2
unit for prop
                  kg                  mm                  ms
/PROP/SPRING/2/2
Seatbelt
#                  M                               sensor_ID    Isflag     Ileng
                5E-5                                       0         0         1
#                 K1                  C1                  A1                  B1                  D1
               0.001                   0                   0                   0                   0
# fct_ID11        H1  fct_ID21  fct_ID31  fct_ID41                     delta_min           delta_max
         1         2         0                   0                             0                   0
#                 F1                  E1             Ascale1             Hscale1
                   0                   0                   0                   0
/MOVE_FUNCT/1
Seatbelt
#           Ascale_x            Fscale_y            Ashift_x            Fshift_y
                                   0.001
/FUNCT/1
Seatbelt loading force vs engineering strain
#                  X                   Y
                  0.                  0.
               0.005                700.
                0.02               3100.
                0.03               5500.
                0.15              17000.
               1000.              17000.
#ENDDATA
  1. The spring has one translational degree of freedom in the local x direction which is defined between node N1 and N2 of the spring.
  2. Spring is activated and/or deactivated by sensor defined in sens_ID and depends on Isflag:
    • If Isflag = 0, the spring element is activated by the sens_ID and cannot be deactivated. The initial length of the spring is based on the spring length at time=0.
    • If Isflag = 1, the spring element is deactivated by the sens_ID and cannot be activated. The initial length of the spring is based on the spring length at time=0.
    • If Isflag = 2, the spring is activated and/or deactivated by sens_ID and can switch activation state multiple times. If sensor is activated, the spring is active; if sensor is deactivated, spring is deactivated. The spring initial length, l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGSbWaaSbaaSqaaiaaicdaaeqaaaaa@3AAE@ , is the distance between spring nodes at the time of sensor activation.
  3. If Ileng = 1, the spring properties are based on the initial spring length. The input should be entered as:
    M = m l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbGaey ypa0ZaaSaaaeaacaWGTbaabaGaamiBamaaBaaaleaacaaIWaaabeaa aaaaaa@3B0F@ K = k * l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbGaey ypa0Jaam4AaiaacQcacaWGSbWaaSbaaSqaaiaaicdaaeqaaaaa@3BA9@
    C = c * l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGdbGaey ypa0Jaam4yaiaacQcacaWGSbWaaSbaaSqaaiaaicdaaeqaaaaa@3B99@
    Each spring will then have the following properties in the model:
    m = M l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGTbGaey ypa0JaamytaiabgwSixlaadYgadaWgaaWcbaGaaGimaaqabaaaaa@3D49@ k = K l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGRbGaey ypa0ZaaSaaaeaacaWGlbaabaGaamiBamaaBaaaleaacaaIWaaabeaa aaaaaa@3B0B@
    c = C l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGJbGaey ypa0ZaaSaaaeaacaWGdbaabaGaamiBamaaBaaaleaacaaIWaaabeaa aaaaaa@3AFB@
    Where,
    M MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ , K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ and C MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@
    Spring values entered in the spring property fields
    m MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ , k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ and c MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@
    Spring’s actual physical mass, stiffness and damping
    l 0
    Initial spring length which is the distance between node N1 and N2 of the spring
    δ min 1  and  δ max 1 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda qhaaWcbaGaciyBaiaacMgacaGGUbaabaGaaGymaaaakiaabccacaqG HbGaaeOBaiaabsgacaqGGaGaeqiTdq2aa0baaSqaaiGac2gacaGGHb GaaiiEaaqaaiaaigdaaaaaaa@452A@
    Failure values entered as engineering strain
  4. Force computation. For additional information, refer to Stiffness Formulation in the User Guide.
    • If Ileng =0, the value of force F MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGgbaaaa@3729@ in the spring is computed as:
      For H1 = 1,2,4,5,6,7:(1)
      F = f ( δ A s c a l e 1 ) [ A 1 + B 1 ln ( max ( 1 , | δ ˙ D 1 | ) ) + E 1 g ( δ ˙ F 1 ) ] + C 1 δ ˙ + H s c a l e 1 h ( δ ˙ F 1 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGgbGaey ypa0JaciOzamaabmaabaWaaSaaaeaacqaH0oazaeaacaWGbbGaam4C aiaadogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaaGymaaqabaaaaa GccaGLOaGaayzkaaWaamWaaeaacaWGbbWaaSbaaSqaaiaaigdaaeqa aOGaey4kaSIaamOqamaaBaaaleaacaaIXaaabeaakiGacYgacaGGUb WaaeWaaeaaciGGTbGaaiyyaiaacIhadaqadaqaaiaaigdacaGGSaWa aqWaaeaadaWcaaqaaiqbes7aKzaacaaabaGaamiramaaBaaaleaaca aIXaaabeaaaaaakiaawEa7caGLiWoaaiaawIcacaGLPaaaaiaawIca caGLPaaacqGHRaWkcaWGfbWaaSbaaSqaaiaaigdaaeqaaOGaci4zam aabmaabaWaaSaaaeaacuaH0oazgaGaaaqaaiaadAeadaWgaaWcbaGa aGymaaqabaaaaaGccaGLOaGaayzkaaaacaGLBbGaayzxaaGaey4kaS Iaam4qamaaBaaaleaacaaIXaaabeaakiqbes7aKzaacaGaey4kaSIa amisaiaadohacaWGJbGaamyyaiaadYgacaWGLbWaaSbaaSqaaiaaig daaeqaaOGaciiAamaabmaabaWaaSaaaeaacuaH0oazgaGaaaqaaiaa dAeadaWgaaWcbaGaaGymaaqabaaaaaGccaGLOaGaayzkaaaaaa@72CB@
    Where, δ = l l 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazcq GH9aqpcaWGSbGaeyOeI0IaamiBamaaBaaaleaacaaIWaaabeaaaaa@3CBF@ is the difference between the current length and the initial length of the spring element.
    with l 0 < δ < + MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqGHsislca WGSbWaaSbaaSqaaiaaicdaaeqaaOGaeyipaWJaeqiTdqMaeyipaWJa ey4kaSIaeyOhIukaaa@3F2D@
    If H1 = 8:(2)
    F = f ( l A s c a l e 1 ) [ A 1 + B 1 ln ( max ( 1 , | δ ˙ D 1 | ) ) + E 1 g ( δ ˙ F 1 ) ] + C 1 δ ˙ + H s c a l e 1 h ( δ ˙ F 1 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGgbGaey ypa0JaciOzamaabmaabaWaaSaaaeaacaWGSbaabaGaamyqaiaadoha caWGJbGaamyyaiaadYgacaWGLbWaaSbaaSqaaiaaigdaaeqaaaaaaO GaayjkaiaawMcaamaadmaabaGaamyqamaaBaaaleaacaaIXaaabeaa kiabgUcaRiaadkeadaWgaaWcbaGaaGymaaqabaGcciGGSbGaaiOBam aabmaabaGaciyBaiaacggacaGG4bWaaeWaaeaacaaIXaGaaiilamaa emaabaWaaSaaaeaacuaH0oazgaGaaaqaaiaadseadaWgaaWcbaGaaG ymaaqabaaaaaGccaGLhWUaayjcSdaacaGLOaGaayzkaaaacaGLOaGa ayzkaaGaey4kaSIaamyramaaBaaaleaacaaIXaaabeaakiGacEgada qadaqaamaalaaabaGafqiTdqMbaiaaaeaacaWGgbWaaSbaaSqaaiaa igdaaeqaaaaaaOGaayjkaiaawMcaaaGaay5waiaaw2faaiabgUcaRi aadoeadaWgaaWcbaGaaGymaaqabaGccuaH0oazgaGaaiabgUcaRiaa dIeacaWGZbGaam4yaiaadggacaWGSbGaamyzamaaBaaaleaacaaIXa aabeaakiGacIgadaqadaqaamaalaaabaGafqiTdqMbaiaaaeaacaWG gbWaaSbaaSqaaiaaigdaaeqaaaaaaOGaayjkaiaawMcaaaaa@7217@
    Where, 0 < l < MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaqGWaGaey ipaWJaamiBaiabgYda8iabg6HiLcaa@3B7B@ and l 0 < δ < + MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqGHsislca WGSbWaaSbaaSqaaiaaicdaaeqaaOGaeyipaWJaeqiTdqMaeyipaWJa ey4kaSIaeyOhIukaaa@3F2D@
    If Ileng = 1, the value of force F MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGgbaaaa@3729@ in the spring is computed as:(3)
    F = f ( ε A s c a l e 1 ) [ A 1 + B 1 ln ( max ( 1 , | ε ˙ D 1 | ) ) + E 1 g ( ε ˙ F 1 ) ] + C 1 ε ˙ + H s c a l e 1 h ( ε ˙ F 1 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGgbGaey ypa0JaciOzamaabmaabaWaaSaaaeaacqaH1oqzaeaacaWGbbGaam4C aiaadogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaaGymaaqabaaaaa GccaGLOaGaayzkaaWaamWaaeaacaWGbbWaaSbaaSqaaiaaigdaaeqa aOGaey4kaSIaamOqamaaBaaaleaacaaIXaaabeaakiGacYgacaGGUb WaaeWaaeaaciGGTbGaaiyyaiaacIhadaqadaqaaiaaigdacaGGSaWa aqWaaeaadaWcaaqaaiqbew7aLzaacaaabaGaamiramaaBaaaleaaca aIXaaabeaaaaaakiaawEa7caGLiWoaaiaawIcacaGLPaaaaiaawIca caGLPaaacqGHRaWkcaWGfbWaaSbaaSqaaiaaigdaaeqaaOGaci4zam aabmaabaWaaSaaaeaacuaH1oqzgaGaaaqaaiaadAeadaWgaaWcbaGa aGymaaqabaaaaaGccaGLOaGaayzkaaaacaGLBbGaayzxaaGaey4kaS Iaam4qamaaBaaaleaacaaIXaaabeaakiqbew7aLzaacaGaey4kaSIa amisaiaadohacaWGJbGaamyyaiaadYgacaWGLbWaaSbaaSqaaiaaig daaeqaaOGaciiAamaabmaabaWaaSaaaeaacuaH1oqzgaGaaaqaaiaa dAeadaWgaaWcbaGaaGymaaqabaaaaaGccaGLOaGaayzkaaaaaa@72D5@
    Where,
    ε MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH1oqzaa a@3805@
    Engineering strain
    ε = δ l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH1oqzcq GH9aqpdaWcaaqaaiabes7aKbqaaiaadYgadaWgaaWcbaGaaGimaaqa baaaaaaa@3C97@
    f ( ε ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaacqaH1oqzaiaawIcacaGLPaaaaaa@3A7A@
    Nonlinear stiffness is a function of engineering strain
    g ( ε ˙ )  and  h ( ε ˙ ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbWaae WaaeaacuaH1oqzgaGaaaGaayjkaiaawMcaaiaabccacaqGHbGaaeOB aiaabsgacaqGGaGaamiAamaabmaabaGafqyTduMbaiaaaiaawIcaca GLPaaaaaa@42AC@
    Damping is a function of engineering strain rate
  5. If H1 > 0 and fct_ID11 = 0, f ( δ ) = 1  or  f ( ε ) = 1 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaacqaH0oazaiaawIcacaGLPaaacqGH9aqpcaaIXaGaaeiiaiaa b+gacaqGYbGaaeiiaiGacAgadaqadaqaaiabew7aLbGaayjkaiaawM caaiabg2da9iaaigdaaaa@4543@ .
