/SURF/PLANE
Block Format Keyword Describes an infinite PLANE surface defined by a normal vector MM1.
/SURF/PLANE/surf_ID/unit_ID | |||||||||
surf_title | |||||||||
XM | YM | ZM | |||||||
XM1 | YM1 | ZM1 |
Definition
surf_ID | Surface
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
surf_title | Surface
XM | X
coordinate of M (end of normal
vector) (Real) |
YM | Y
vector) (Real) |
ZM | Z
vector) (Real) |
XM1 | X
coordinate of M1 (head of normal
vector) (Real) |
YM1 | Y
vector) (Real) |
ZM1 | Z
vector) (Real) |
- The infinite
PLANE is defined by a normal vector MM1 (M belongs to plane).Figure 1.
