::SetState
This command will enable or disable the mdlTempListCollector widget.
::model::mdlTempListCollector::SetState argFrm argState
MotionView Tcl
- argFrm
 - We need to pass the path of the mdlTempCollector which needs to be enabled or disabled.
 - argState
 - We need to pass either true (1) to enable or false (0) to disable the mdlTempListCollector.
set sel_pt ""
set sel_vec ""
set sel_type ""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set types {{Point Point ::sel_pt} {Vector Vector ::sel_vec}}
set list_col [::model::mdlTempListCollector $colFrm.lcol ::sel_type "$types"]
pack $list_col
::model::mdlTempListCollector::SetState $list_col false
      Error
On successful execution of the command, the mdlTempListCollector will be enabled or disabled.
