pltIPlot CopyCurve
Copies the curve to the internal clipboard.
pltIPlot_handle CopyCurve index, append
HyperWorks Tcl Modify
- index
 - The number of the curve.
 - append
- True
 - Appends the curve to other copied curves in the clipboard.
 - False
 - Replaces the contents of the clipboard with the curve.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName CopyCurve 1 0
myPlotName PasteCurve 0
Returns success or an error code.
