pltIPlot GetPhaseZeroAtTop
Finds whether the phase axis position begins at the top or the right side.
pltIPlot_handle GetPhaseZeroAtTop state
HyperWorks Tcl Query
This command finds if the the phase axis begins at the top of the circular plot (vertically). If the phase axis begins at the top of the circular plot (at the value zero), true is output. Otherwise, the phase axis begins horizontally, and a false is output.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetPhaseZeroAtTop;
Success (a true or false value) or an error message is returned.
Keywords
HyperWorks
Tcl
Polar Plot
Query
