pltIPlot PasteVerticalAxes
Pastes previously copied or cut vertical axes.
pltIPlot_handle PasteVerticalAxes index
HyperWorks Tcl Modify
This command pastes previously copied or cut axes into the axes list.
- index
 - The index (position number) where you want to insert the axes. PasteVerticalAxes pastes the user-input index and moves the list down one position if it is at or below that index.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot PasteVerticalAxes 3;
Keywords
HyperWorks
Tcl
XY plot
Modify
